  • Online today: 8
  • Guests: 9
  • Total: 9
payment at last
Started by alan1572, August 21, 2010, 08:20:41 AM
alan1572
i got back from a 4 day golfing break to find that i have the cheque to replace my camera :beer:, i want to stay with Nikon but is the D300 still the best option for the money?
Who wanted dry roasted with their pint?
i know i'm not a Nikon user - but if were going to look at a Nikon i'd be going for the D700.
Almost a stripped down D3.
You ask anyone who has a D300 and D700 and i'm betting that the D300 only comes out as a second camera to avoid lens changing...
alan1572
i'll have a look at 1 while i wait for the funds to clear
Quote from: picsfor on August 21, 2010, 08:42:27 AM
        Well Andrew, since you mention it, I do have a D300 and a D700, and as luck would have it, the D300 is for sale along with it's DB10 battery pack!
                           Graham. ;) :tup:
Quote from: alan1572 on August 21, 2010, 08:20:41 AM
Good result Alan.  Glad you got that sorted.  :tup:
Quote from: Graham on August 21, 2010, 09:15:08 AM
                           Graham. ;) :tup:
Graham, might be worth adding it to the Items for sale  I know some of the guys have had results doing this.  ;)
Quote from: admin on August 21, 2010, 09:23:21 AM
                           Graham. ;) :tup:
Will do Mick. Iv'e just got to sort out what to include.
                            Cheers.  Graham.
Look at the D300s as it might do all you need. Suggest you go into a camera shop like Jessops and feel both cameras to see which might suit you best. Glad you sorted out the insurance claim.  ;D
rksmith51
Quote from: Oldboy on August 21, 2010, 09:58:13 AM
Like olboy said, its very very important to hold the cameras in your hand, the 700 has a better high iso range and is full frame, so find out if any lenses you have are compatible.
Bob
Hi, "Guest" long time no see, how are you
alan1572
the lens' that i have are
105mm vr micro N
12-24mm 1:4 G ED DX
AFS VR 70-200mm 1:2.8 G
AF-S 18-70mm G ED DX
the lens that came with the camera was with the body
is there a site to see if they will fit the d700?
Yeah - right here ;)
105 and 70 - 200 will work perfectly.  The DX lenses will work fine but will cause severe vignetting unless you turn the sensor down to 5 million pixels.  It's possible the camera will do this automatically (though it can be overridden).
@Graham - how much?  I need a small / light 3rd body now the D2s have gone.  Idly wondering about a D50 or D3100 but D300 would do if it was cheap :)
Quote from: Jonathan on August 21, 2010, 01:13:43 PM
        I'll send you a p/m.
                    Graham.
alan1572
#11
[quote author=Jonathan link=topic=1529.msg17526#msg17526 date=1282392823
[/quote]
what are ideal replacements ? it will depend on the prices as to whether i upgrade.
what ever you do Alan - do not pop into the shop and try out a D700 before you get the prices to work out if you're going to upgrade.
Cos once you do - you'll leave the shop with one. And i'm a Canon owner  :tup:
alan1572
i did go into a shop in Wigan today but they don't stock anything over £350, probably for the best ;D
Quote from: alan1572 on August 21, 2010, 12:38:11 PM
105mm vr micro N
12-24mm 1:4 G ED DX
As JR says, the 105mm VR will work fine. The 70-200mm F2.8 VR will work fine at F4 or greater but at F2.8 you may see dark corners. This is why I use a 1.4 converter mostly with mine, as a carry round lens. The 12-24mm F4 will work fine with a FX from 17mm and above, but below this it will show dark corners. The 18-70 is useless on a full frame camera. And yes I have all these lenses.  :tup:
As to which ones to get then suggest the Nikon 24-70mm F2.8 but might be a bit expensive at just under £1,200. Greys of Westminister have a 35-70mm F2.8 secondhand at £395. If that's too dear then consider the Tokina 28-70 Pro-X F2.8 but I can't find one on the web. Strange as I brought mine form Jacobs for about £210, as I couldn't get the Nikon 24-70mm F2.8 at the time. Have a look at other AIS lenses as most of those were made for film cameras and work fine with full frame digital cameras. Just check the chart on Nikon's website to make sure they work with full frame digital cameras.  ;D
